10-14-2016
04:20
05:55
AlejandraFitbit
10-14-2016
04:20
05:55
AlejandraFitbit
After latest update phone won't reset after midnight unless my phone bluetooth and internet is on. Before the update it would reset the steps and everything after midnight without having to turn on my bluetooth and internet.
Moderator edit: Format & Subject for clarity
05:57
05:27
10-14-2016
05:57
05:27
A warm welcome to the Community @42451. This is weird since keep in mind that the tracker and the Fitbit app work with internet connect and bluetooth on. If you want your tracker to sync without and inconvenience and see that it resets at midnight, I recommend having the bluetooth enabled and internet connection.
See you around. ![]()
06:17
07:04
AlejandraFitbit
10-14-2016
06:17
07:04
AlejandraFitbit
Before the last update. I would only turn on my internet and bluetooth when I wanted the app to sync with my watch. Now after the update the same number of steps I had the day before will still be on the watch the next morning and it does not reset the steps on my watch until I turn on the bluetooth and internet. I was hoping it could it could go back to the way it was where the watch reset it's steps at midnight, that way I only have to turn on the internet and bluetooth once to sync and not leave it on all day to drain my phone battery.
07:08
05:27
10-14-2016
07:08
05:27
Thanks for the clarification @42451. Since it's your tracker the one that is not resetting at midnight. I recommend restarting your Blaze to avoid this to happen again. Also, you can check your timezone settings by doing the following from a computer:
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner.
2. Select “Settings” from the drop-down menu.
3. Scroll down to the Time section and choose the time zone that best reflects your current location. You can also select 12-hour or 24-hour time display format here.
4. Sync your tracker to update your time zone.
Please test your tracker today to see if it resets at midnight and if it doens't, feel free to get in touch with our support team. For a faster response you can contact them via phone or chat.
Let me know the outcome. ![]()
04:00
04:05
AlejandraFitbit
11-14-2016
04:00
04:05
AlejandraFitbit
That did not work either. I guess it's just the way it is. It's a shame really I liked only having to turn my internet and bluetooth on when I wanted it to sync with my phone. I guess I will have to change my routine a bit. I just hate keeping the bluetooth and internet on (battery drain).
Moderator edit: All caps
04:06
05:27
11-14-2016
04:06
05:27
Thanks for the information @42451. If the steps provided didn't work, I recommend getting in touch directly with our support team, I know they will be glad to help you out. For a faster response you can contact them via phone or chat.
Catch you later. ![]()
Best Answer11-15-2016 13:57
11-15-2016 13:57
@42451 what @AlejandraFitbit suggested, unfortunately probably won't affect today's miscount in steps, but should keep it from happening in future nights.
One thing that will cause the days steps to carry over is if a user changes timezones between 11:00pm and midnight.
Best Answer11-15-2016 20:57
11-15-2016 20:57
