Hey there @MK-BLAZE. Great to see you in the Community! 🙂
I'm sorry to hear that your Blaze is not syncing after charging it 😕 Have you tried by any chance to restart it? You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
After that, you can try to set it up as a new device. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
Hope this helps. Let me know how it goes!
Best AnswerCheck you Bluetooth to make sure it is connected.
