05-14-2016 14:22
05-14-2016 14:22
So I'm using it on the treadmill and I noticed compared to my fitbit One the blaze is way off on the steps. I;m right handed and wear it on my left and have it set for non dominant hand. So I did an hours on the treadmill and it's over 3000 steps off. I counted my steps for a minutes and it's 146 the fitbit only registers 105 steps so for evey 10 minutes I'm off almost 450-500 steps then my normal pace for for an hours it's off 3000 steps. The distance I did on the treadmill was 4.6 miles and on the fitbit it shows 3.1 miles. I even used the treadmill setting.
I regret getting this item and will probably send it back and just use the one. The only issues is I got it through my works get active program and got it for $136. If I send it back I want my reward back and I want to use it for the aria scale which was $63. Buyer beware!
Best Answer05-14-2016 16:39
05-14-2016 16:39
Are you holding on to the hand rail?
This may prevent the Fitbit from seeing arm motions that look as if your running.
Best Answer05-14-2016 21:54
05-14-2016 21:54
Best Answer05-15-2016 14:02
05-15-2016 14:02
My Blaze is not accurately tracking my steps. My Flex tracked very well, but the Blaze shows 1 step for every 5-6 I take. I am wearing it on my non-dominant arm and have it set to non-dominant. Any suggestions?
