Notification Issue with oppo f1s
So as it is Christmas I just received the Fitbit Blaze as a happy person used it.
The notifications on the phone app worked for a short bit of time (Mind you, I did not actually try and see if a notification came up). But when I got a message it never came up (and you might be thinking "well maybe that's cause of what it was set on" and I thought the same) so I went into the app and it told me to enable the notification (i had already done it so I was a little confused) so I clicked the button but to my surprise it was on and enabled but just sitting idol on that screen and would not progress.
can anyone help me out to get it to work
because before it came up with call options and text options now it just wants it enabled and every time I try it comes up with the same screen asking for the notification centre to be activated when it already has a green tick next to it.
Please help I don't want to buy a new phone just because of this issue
This also includes the music issue but I'm not as worried about that
1 REPLY 1
A warm welcome to the Community @Milly1223, thanks for troubleshooting this by yourself.
If you are having issues with your notifications, I recommend taking a look at the My tracker isn't receiving notifications (Android Fitbit app) post and follow the instructions provided there.
I hope this helps, let me know the outcome. Woman Happy
