02-29-2016 20:11
02-29-2016 20:11
03-01-2016 10:27
03-01-2016 10:27
@Chinz Welcome to the Fitbit Community! Follow these troubleshooting steps for notifications. It should work properly. Also, you can try to log out from the app, reboot your phone, and log back in to your account.
Try that out and let me know how it goes!
09-29-2016 08:02
09-29-2016 08:02
Hello,
I have a galaxy S4 and I lost the notifications after the app be updated for the version 2.33 and I have the same issue with the version 2.34. The version 2.32 had working properly.
I followed the tips described in the "Fitbit Help" but without success.
Someone have any solution for this issue?
Thank you,
Paulo
09-29-2016 11:46 - edited 09-29-2016 11:47
Hello @FbBpm a couple things to check:
Does the Blaze show up as connected in your phones BT settings?
Swipe down on the notification panel, do you see an entry saying Fitbit notifications running?
Under the Fitbit app's notification settings, is the notification widget enabled?
Go back one level, is always connected enabled.
One more, the hamburger menu, 3 dots, on the top right of the notifacation settings has a test function. Did the test come through?
Just a few things to check and try.
09-29-2016 15:41
09-29-2016 15:41
Hello @Rich_Laue,
I had already tried the suggested topics and all of them are working, except the test fuction.
I have tried other settings one of which was turn on the "Do Not Disturb" and after turn off the "Do Not Disturb" on the phone, after this, the notifications start work, I don't know if that was the problem, but now everything is working.
Thank you for your feedback.
Best regards.
10-09-2016
05:25
10:53
10-09-2016
05:25
10:53
Great to see you in the Community @FbBpm! 🙂
I'm glad to hear that the suggestions that @Rich_Laue provided helped to solve your problem. Sometimes as with any device, when some features fail to work, disabling and enabling them is a good call to make them work again and it seems that was the case here.
Let us know if you need any more help in the future!
