03-04-2016 20:40
03-04-2016 20:40
03-05-2016 02:32
03-05-2016 02:32
The buzzing should happen automatically..
Feel free restarting the tracker:
Restart the tracker
URL: Click / Tap to open the Fitbit Help Article 'How do I restart the tracker?'
Hope it helps
03-05-2016 02:32
03-05-2016 02:32
Restart the tracker
Hope it helps
07-14-2016 13:43
07-14-2016 13:43
I have the same problem - this is a deal breaker...returning the blaze and going back to the charge HR....very disappointed with the blaze in general
@SunsetRunner wrote:The buzzing should happen automatically..
Restart the tracker
Hope it helps
07-15-2016 20:45
07-15-2016 20:45
07-16-2016 05:25
07-16-2016 05:25
I solved my problem by packing my blaze up and returning it. I love my Charge HR, but was very disappointed in the blaze. THe lack of reliable notifications and weak vibtation alerting were deal breakers for me.
07-16-2016 12:31
07-16-2016 12:31
I don't feel the alarms on the Blaze when I'm sleeping, like I did with the Fitbit Charge.
It fails to wake me up now, I might try to set the vibrations to a higher level, to see if that works out.
I know that the vibrations are working, they're just not strong enough.
08-17-2016 22:02
08-17-2016 22:02
The alarm notification vibrations are much too weak for the average person to notice. They need to be made stronger in a firmware update, if that's possible.
08-23-2016
08:24
10:55
08-23-2016
08:24
10:55
Hi there everyone! It's great to see you in the Community!
There is a feature request for making vibrations on the Blaze stronger. You can vote for it here.
In the meantime, I would recommend in the meantime, wearing your tracker a little bit tighter while you sleep (not too tight) to ensure that you will feel the vibrations.
For those having issues with the Blaze not vibrating at all, a restart by pressing the left and lower right buttons for about 10-12 seconds should help. If this doesn't make a difference, feel free to get in touch with the Support Team and they will be very happy to help you out with this!
Anything else, let me know!
