09-11-2019 17:35
09-11-2019 17:35
Hi I'm on holiday in Turkey. My watch won't sync . I've tried everything. Even unistalled the app. But it still won't sync. Any idea's on how to please.
Best Answer09-11-2019 17:46
09-11-2019 17:46
Do you have wi-fi connection for your phone? If you only have data through cellular then check to make sure you have allowed data through cellular connection. Also the Fitbit unit will store detailed data for 7 days and summary data for about a month. You won't lose any data as long as you can get it to sync within the 7 days storage time.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
09-11-2019 17:58
09-11-2019 17:58
I've got wifi connection. But no mobile data. I've checked all settings. Location on. Connection on. But still won't sync
Best Answer09-11-2019 18:07
09-11-2019 18:07
That does stump me. My wife and I were overseas last month and had turned off mobile but we had WiFi and had no problems syncing. One last thing I can think of is to check your Bluetooth.
09-11-2019 18:24
09-11-2019 18:24
Just got worse. I went to switch my watch off. The back light on the hmm blaze is on. But the watch won't turn on now 😢
Best Answer09-12-2019 12:13
09-12-2019 12:13
As for not turning on. Have you tried restart g whole in is charger. It is not easy but possible, have reported success.
As for the sync issue, it should work thrughbo in eityer wifi or cellular. I'm not sure which wifi you are attaching to but it may be possible that they have blocked the port Fitbit uses.
