06-14-2017 19:41
06-14-2017 19:41
So I bought a blaze today. Woohoo. It connected the first time synced and was great. Then it wouldn't sync again. So I deleted the app and reinstalled it and now the blaze won't connect at all. Says turn off Bluetooth and turn back on. Reset blaze. And make sure battery is good.. I've done all of this. And it won't work. Earlier it worked fine. Idk what happen or what I can do
Best Answer06-14-2017 19:24
06-14-2017 19:24
Best Answer06-14-2017 20:15
06-14-2017 20:15
Welcome to The forums!
Is the device on the supported list?
https://www.fitbit.com/devices
If it is not there can you set it up on a computer?
http://help.fitbit.com/articles/en_US/Help_article/1873
Hope to see you around!
Wendy | CA | Moto G6 Android
