I have Fitbit and MFP connected to each other but for some reason Fitbit will not import or update food/calorie intake unless I tap into the food portion of the dashboard that day. If I forget to tap in on a given day (Monday and yesterday, in this case) I cannot get it to import for either day, nor can I figure out how to just bulk add the calories for each day. I disconnected the apps from each other and reconnected, with no change.
Hello all,
First let me advise you that your Blaze will only sync to your Fitbit account.
Second point is the MFP syncs with the user account.
Third point is that third parties are responsible for their Fitbit connection. This is a problem for MFP not fitbit
, This is how Third parties interface with Fitbit.
So let's go to the third party board and read the pinned update. From here we see!..
You may also want to read from Fitbits post
