11-07-2016
08:21
05:44
FerdinandFitbit
11-07-2016
08:21
05:44
FerdinandFitbit
I appreciate my wife getting me a Blaze, it seemed like a good idea at the time, but the dahsboard software has too many problems, it frequently stops syncing, and valuable data is lost or not collected at all. The fact that sooooo many others are posting similar problems indicates that Fitbit is not serious about delivering a quality product. I will look elsewhere for a better product in the future. The Garmin Vivosmart looks much more reliable for about the same price. As a researcher in data science I was hoping the data might be useful in some way, but unfortunately there are too many problems with it and it is unreliable for anything but a novel look every now and then. Why spend $200 for worthless data??
11-08-2016
05:50
08:38
11-08-2016
05:50
08:38
Hi there @jsale. Welcome to the Fitbit Community! 🙂
I'm sorry you're having problems with your tracker 😕
If your tracker is not syncing properly, something that takes care of this is restarting it. For this, just press and hold the left and lower right buttons for 10-12 seconds. This will make the tracker to reboot and refresh the connection to your phone. Additionally you can also restart your bluetooth by simply turning it off and back on and after that, try it out for the next days and see if this makes any difference.
If that doesn't work, you can also set up your tracker as a new device by going to the account section on your app and once you're there, tap on the "Set up a new device" option and follow the on-screen instructions and see how it goes after that.
Hope this works and if you need more help with this, let me know!
11-08-2016 06:03
11-08-2016 06:03
For the occasional times my tracker doesn't sync, or notifacations don't come through, with the latest update, i find that restarting the tracker doesnt work for me but restarting the phone does. This has been my experience, yours may vary .
11-09-2016 13:53
11-09-2016 13:53
11-09-2016 18:32
11-09-2016 18:32
11-09-2016 18:48
11-09-2016 18:48
@lauraneumiller when you do a forget device, you go to your phones Bluetooth settings and tell it to forget the Blaze. Blaze classic can be left alone.
Now open the app and sync, the app will pair the tracker to the phone. Removing it from the account does not remove it from the phone and usually does not help with solving a sync problem.
11-09-2016 18:56
11-09-2016 18:56
11-09-2016 21:15
11-09-2016 21:15
03:18
08:39
11-10-2016
03:18
08:39
Great to see you around @Rich_Laue, @jsale, @lauraneumiller and @Aclobos. If you have already tried the instructions provided by our friend @FerdinandFitbit and keep having problem with your Blaze, please get in touch with our support team for further assistance. For a faster response you can contact them via phone or chat.
Catch you later. ![]()
01-18-2017 06:11 - edited 01-18-2017 06:13
I wanted to follow up with some details which others may find useful. I gave my Blaze to my wife and I did in fact buy a Garmin Vivosmart HR+ and I am happy enough with it, but there are a couple of things which the Blaze does better. First, the Vivosmart display is difficult to read. It is a more narrow display than the Blaze and they use a condensed font as a result. Also, it is not color like the Blaze. The color was really nice. The quality of the Vivosmart data is excellent, exactly what I am looking for, but I can't easily get to all of my data. Fitbit offers a really nice api which gave me access to all of my data. Garmin only lets me download data if it is recorded as an "Activity", which means I need to set my watch as a perpetual Activity to save all of my data. It's a little bit of extra work and I find I don't always do it. I could be wrong, but I believe that if I want to pay $5000 I can develop for the Garmin platform and get access to their api. The Vivosmart data itself is excellent, and it includes GPS integrated together with the physio data and time stamped. FWIW, my wife is very happy with her Blaze, but she's not into the data like me.
01-19-2017 07:12
02-14-2017 11:37
02-14-2017 11:37
I have also had endless problems with my Blaze. It works for a week, then it stops syncing, and it stops notifying me of calls, etc. I have spent countless hours on the phone with tech support, and reset, uninstalled, unpaired...you name it. I recently upgraded my phone and thought, hey maybe it was the phone. But alas, same problems as before.
To add insult to injury, tech support told me that I have to return it and they will send me a new one. The first package included everything bit the actual piece. I got a new charger, new band....no mechanism. So I had to go back to the post office and return that. Then they sent me a crappy metal wristband which in no way will fit my 5" wrist, a silicone band, the charger, the mechanizm, but no square piece so I could use the silicone band.
So I had to buy a piece to discover the same problems occur. So now my total investment is $200 plus another $10 for the piece they left out of the box.
Total waste of time and money. Would never invest in their products again, especially after their spotty support.
02-15-2017 08:20
02-15-2017 08:20
Thank you for letting us know about this issue and how to restart the Blaze. I just spent the last 4-6 hours trying to figure out how to to restart this THING! It worked and now hopefully I won't have any more problems. I have had this Blaze for 4 days now and I had the Charge HR before. Also the battery sucks on this Blaze!
02-15-2017 19:20
02-15-2017 19:20
@LisaSac@So are you saying that your blaze was under warranty and when you received your replacement you did not get a replacement pebble (blaze watch).? Why would you buy a new blaze if your old blaze was still under warranty? If you just bought a new blaze and your old blaze is under warranty, I would return your blaze for full refund and request customer support to replace your blaze under your warranty.
Best Answer02-15-2017 19:25
02-15-2017 19:25
02-15-2017 20:10
02-15-2017 20:10
@LisaSacyeah I had some problems with iOS 10.1, I had to uninstall and reinstall my blaze from my iPhone. Also had to power down my iPhone. Found out I had a few to many Bluetooth devices connecting simultaneously on my iPhone, after disconnecting a few unnecessary devices my blaze worked. One thing for sure this blaze always keeps you on your toes. There's always something that comes up unexpectedly. Sorry to hear things didn't work out.
Best Answer02-15-2017 20:15
02-15-2017 20:15
02-15-2017 20:15
02-15-2017 20:15
02-15-2017 21:03
02-15-2017 21:03
Best case is I usually get about 2 days betwen having to flush everything and start over. Not acceptable. Chalk this one up to a lesson learned I guess....
02-18-2017 08:56
02-18-2017 08:56
think i've figured out a workaround. turn off all-day sync and restart my blaze everytime before i sync. it seems to sync ok, so far anyway.
