02-28-2016 07:21
02-28-2016 07:21
Best Answer02-28-2016 07:40
02-28-2016 07:40
Hey @Jlanny312. I think I can help you with this. Welcome to the Fitbit Community by the way! 🙂
There is currently no setting for the QuickView feature to be more sensitive. What I can suggest would be to restart your tracker and just make sure to turn your wrist at least 30-45 degrees (based on my own experience) for your Blaze to show the time.
Now, whenever you have "All-day sync" enabled, your tracker will constantly sync (every 15-20 min) even if you have the app running in the background but if you don't want this to happen, you can just turn it off and everytime you open up the app it will sync and update your dasboard. The advantage of having it on all the time is that your dashboard will be constantly updated but if you don't mind about this and it's okay for you to have your dashboard updated until you open up the app, that's fine.
Hope this answers your question and if you need anything else, feel free to let us know!
02-28-2016 08:04
02-28-2016 08:04
@Jlanny312 lets start with Quickview.
No there is no adjustment to fine tune.
Put the watch back on, now that you know what the watch wants to see.
With the arm by your side lift it up to your face
After the arm gets to about horizontal
Gently twist the wrist so the clock face is vertical.
When lowering the am it will turn off.
Ok let's look at the BT pairing,
02-28-2016 07:40
02-28-2016 07:40
02-28-2016 07:50
02-28-2016 07:50
02-28-2016 07:57
02-28-2016 07:57
That's a very good suggestion @Jlanny312.
You can take a look at our Feature Suggestion board and see if there is already a suggestion for this and if not, you can create your own for others with the same suggestion to vote for it and for this to be taken into consideration.
Best Answer02-28-2016 08:04
02-28-2016 08:04
