I have been experiencing the same problem with my Blaze. This only happens when workout is 5 miles or greater. Thankfully, I use MapMyFitness simultaneously so the workout data is not completely lost. After waiting several days the workout still doesn't sync. Is there a solution to this problem?
07:30
07:03
07-26-2016
07:30
07:03
Hey, @ArthurL! Welcome aboard! I moved your post to the correct board, just to keep things more organized. I hope you don't mind! 🙂
Hmm... This is weird. First make sure that your tracker's firmware is updated! Then I suggest you to restart your tracker, and finally if this doesn't resolve your issue you can try to set it up as a new device.
I hope this helps, let me know how it goes! ![]()
