03-02-2017 19:10
03-02-2017 19:10
Tonight my blaze started flashing red lights for just a few seconds. I've never noticed that before. Should I be concerned?
Best Answer03-02-2017 19:38
03-02-2017 19:38
@Lucy60Welcome.... Was it a small reflective light in the top left hand corner of the Blaze.. If so you are seeing reflection form the detector for the available light strength to enable the tracker to display your screen in the optimal light conditions. I may being wrong about the use,but another Fitbitter or Moderator can correct me.
03-02-2017 19:38
03-02-2017 19:38
03-03-2017 00:46
03-03-2017 00:46
Your correct @Colinm39, this is the light sensor, an just some light sorce reflecting off ot.
03-03-2017
03:14
07:22
03-03-2017
03:14
07:22
It's great to welcome you @Lucy60, @Colinm39 and @Rich_Laue thanks for stopping by.
I am glad to see that your inquiry has been answered, if you need anything else, do not hesitate in posting it.
Catch you later. ![]()
03-03-2017 12:36
03-03-2017 12:36
I'm almost certain the red lights was coming from the same source as the green light underneath next to the skin. It happened so quickly I can't be 100% positive. Green lights flashing red. Could that be possible and if so why? Thanks.
Best Answer11-14-2017 06:53
11-14-2017 06:53
I charged my fit bit 2 and then I got a red light. Help!
Best Answer11-14-2017 06:59
11-14-2017 06:59
That's what mine was doing. Tried to reboot but still got red light. Maybe it wasn't charged?
Best Answer11-14-2017 09:06
11-14-2017 09:06
That would not be the sensor on the front.
I'm not sure what the complete color or colors used in the heart rate sensor.. It might be that there is both red and green led's.. Does it stay red?
