02-28-2018 21:39
02-28-2018 21:39
How do I prevent the Fitbit Blaze from incurring roaming charges?
Best Answer03-01-2018 06:11
03-01-2018 06:11
It's great to welcome you @kkor and @SteveH thanks for stopping by.
I agree with our friend here, since the Blaze uses internet to sync, you can avoid syncing your tracker with your mobile's data or keep in mind that you can always sync if you have WiFi.
Catch you later. ![]()
Best Answer03-01-2018 00:15
03-01-2018 00:15
The only way your Blaze will force your phone to access the internet is if you sync it. So, if you disable bluetooth on your phone it will be unable to sync. Your Blaze will happily store data for up to 7 days between syncs.
03-01-2018 06:11
Best Answer03-01-2018 10:19
03-01-2018 10:19
Turn off all day sync
Best Answer03-01-2018 18:50
03-01-2018 18:50
Best Answer03-02-2018 03:11
03-02-2018 03:11
You are welcome @kkor and @Rich_Laue thanks for stopping by.
I am glad to see here that your inquiry has been resolved. If you need anything else, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer03-02-2018 12:30
03-02-2018 12:30
Will look into it, thank you!
