06-24-2017
09:06
04:33
AlejandraFitbit
06-24-2017
09:06
04:33
AlejandraFitbit
Hey all! I apologize if this has been asked a million times before! So I recently got my Blaze (Amazing, love it). I have been tracking my walks/light jog with the Run option. I was looking through the app and saw that there was a "Walk" option. Does the difference in what I choose to track effect the calories it calculates that I burned? Or is it just for accurate distance measurements?
Thank you in advance!!!
Moderator edit: Format
06-28-2017 04:36
06-28-2017 04:36
A warm welcome to the Community @Mendez5721. Don't worry about the activity you selected. I think that jogging is almost the same as running, you just go a little bit slower. From now on, you can select the "Walk" option if you prefer.
If you want to edit the log you already have, you just need to do the following from your Fitbit app:
I hope this helps, let me know the outcome.
06-28-2017 04:36
06-28-2017 04:36
