12-26-2017
13:29
06:15
AlejandraFitbit
12-26-2017
13:29
06:15
AlejandraFitbit
Yep! I'm another mug that thought an S8 would be fine to use with a Blaze. Why do all the people who have posted on here get the same advice, which doesn't work? There is defiantly a problem, the Samsung Galaxy S8 does not reliably communicate with the Blaze. Period!
Moderator edit: Subject and format
12-28-2017 06:16
12-28-2017 06:16
It's great to have you here @ConfusedS8. Regarding to the issue with the connection between the Blaze and the Samsung Galaxy S8/S8+, I recommend taking a look a this post and check the instructions and information provided there.
Catch you later. ![]()
12-28-2017 11:14
12-28-2017 11:14
While a can't say that the ionic has been flawless, I have had no problems witch the blaze it Charge 2. My 2 brothers have no hiccups with the Surge and sister with the alta. Al4 of us have the S8.
Best Answer12-28-2017 11:34
12-28-2017 11:34
Yep when I first got my blaze my s8 worked fine. Then all of a sudden the notifications failed to come through. Contacted support and said they were working on a fix. After several weeks of nothing the notifications started coming through. NOT!
Best Answer12-28-2017 12:21
12-28-2017 12:24
