I have not used my blazer for a while and yesterday when I try it again the screen does not start.
When the blazer is charging the screen is started and I'm able to connect with my mobile and it was updated the the latest version. It also reports that battery is full loaded but as soon as I take it from the charger the display turns off and it doesn't start.
I have tried to restart the device by holding back and select buttons (left and bottom right) but I do not see any Fitbit icon.
Just to mention before that the blazer was working without any problems.
Thanks
Hello @MarVelFit, welcome to the Community forums. Sorry for the late reply.
Thank you for your reply and confirming that you already tried the restart procedure.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about te outcome.
