Hmmm... that sounds strange @Blazegirl and if it has been syncing constantly after the time changed for daylight savings, this shouldn't be happening.
I would recommend restarting your Blaze by pressing the left and lower right buttons for 10-15 seconds until it turns off and turns back on and then you can set your alarms again and get it to sync and see if it works fine now. Also, I would recommend going to your advanced settings on your tracker on your phone to change your time zone to a completely different time zone and after that, change it back to the correct time zone and then sync your tracker and see if this makes any difference.
Hope this helps and let me know if you are still having issues with this. Welcome to the Community! 🙂
