The original clock display on my Blaze is showing a flame icon at the top and the stat cycle at the bottom. The stat cycle defaults to displaying distance - if I want to know my heart rate I have to tap all the way through. Can you set the display on the standard clock face so that the stat cycle defaults to displaying heart rate which you can then tap to cycle through distance, calories, flights of stairs etc?
Best AnswerIf you tap the area showing the distance you should be able to cycle to the heart rate. Don't touch it again and it should stay. I have steps as my default at the bottom, but occasionally I must be touching it and it moves to another stat.
