08-07-2016 20:40 - last edited on 06-27-2019 20:16 by LiliyaFitbit
My battery life has not lasted more than two days. Do I get it changed for a new one haha
@IsaacJong wrote:
Using a fit bit blaze
That's good that it is the Blaze, you posted in the correct area. HaHa
Ok, in all seriousness have you contacted Fitbit yet? They evaluate each case on a one by one basis, and are able to see the backend of the tracker and how frequently it needs to be charged.
Contact link can be found in the top right, click on the gear, or the app under help.
Welcome to the Community @IsaacJong and @Rich_Laue thanks for stopping by and for the instructions provided. If your Blaze is not holding a charge, I recommend following the steps to maximize your tracker's battery life and the battery troubleshoot.
I hope this helps, let me know the outcome. ![]()
