04-20-2017 04:34
04-20-2017 04:34
I'm on Blaze v8.401.3 and I love a lot of the new functionality with the new update. New faces, sleeping functions... Howver, scrolling left, right, up, down and tapping to select is now a test of my patience. For example, if I want to scroll to the right by swiping right to left, often nothing happens or it partially shows the next screen, before reverting to the home screen. I can finally get there after 20-or-so swipes, but now I need to get to my chosen workout. Ugg. If/when I can get to my countdown/timer function in the Blazes screen, by itself, it will put itself in the select countdown time and start scrolling up and and thought it is possessed. I've rebooted the watch about a half dozen times and have watching for updates. Please help!
Best Answer04-20-2017 06:47
04-20-2017 06:47
Welcome to the forums!
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
04-20-2017 06:47
Restart
Contact Support
Best Answer04-20-2017 16:18
04-20-2017 16:18
Three reboots in a row seemed to be the trick. Thank you!
