12-13-2016
14:33
13:18
AlvaroFitbit
12-13-2016
14:33
13:18
AlvaroFitbit
This is probably a very minor issue to most, however its starting to irritate me. Ive had my fitbit blaze now for 6 months (since july this year) and it has truthfully been the best fitness tracker i have ever owned - despite that, i have noticed a few signs of wear and tear on the blaze frame and i was wondering if this is normal. Does anyone else have this issue?
Best Answer12-13-2016 15:49
12-13-2016 15:49
It is man made you know. I think after 6 months that may be normal. Not sure. I had the gun metal and the frame loked pretty sturdy. The best thing about the blaze is that you can change frame anytime you want.
Best
12-13-2016
16:05
08:20
12-13-2016
16:05
08:20
Welcome to the Community @Spartan2117! I'm glad to hear that you're enjoying your Fitbit Blaze. You may want to read the Fitbit Warranty, in this type of cases is best to contact Customer Support so they can further investigate this issue.
Thanks for your advice @pierrotsc!
Hope this helps!
