12-12-2016 18:05
12-12-2016 18:05
I have a Blaze and am trying to connect it to both my iphone and ipad at the same time and one or the other either drops off or will not connect.
Is it possible to have both connected with the blaze at the same time and place?
Best Answer12-12-2016 18:26
12-12-2016 18:26
@57Peter No - that is not possible. You can only do one device at a time. You have to disable bluetooth from one device for it to connect to the other.
Hope that helps you~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer12-12-2016 19:48
12-12-2016 19:48
Best Answer12-13-2016 15:36
12-13-2016 15:36
No it can not be resolved.. Your tracker a BT Client and as any other client it can only talk to one BY server a time.. Why do you need to sync to both at the same time? The only thing a sync does is send the data from the tracker to the Fitbit server.. The apps on the iOS devices get the info to display from the same server.. You can sync through either device, then see your data from either device.. Sync through phone, see your data through the ipad, no problems.
