@Blaneharris, Fitbit will not register your walk until you walked the minimum minutes set in your profile for walking. The default setting is 10 minutes. When you go to your shortcuts from your blaze and select any shortcut, it will start registering your exercise immediately. So if you did not select treadmill from your shortcuts that would be the reason why you lost 10 minutes.
Welcome to the Community @Blaneharris and @Aclobos thanks for stopping by.
I agree with our friend here, you need to be exercising for a minimum of 10 minutes in order for the tracker to register your information or you can select the activity directly from the tracker. I recommend selecting the activity directly from the Blaze.
If you don't have the treadmill option between your exercises, you can add it by doing the following from your Fitbit app:
I hope this helps, let me know the outcome. ![]()
