04-09-2017 19:39
04-09-2017 19:39
Hello I bought fitbit blaze few days ago. Im really happy with it this is my first fitbit. I.be been able too see blaze up quite Rest. Any settings or questions I.ve had. I.ve been able too find answers easily.either in settings or through a online help article
Today I.ve had a rest day. But my blaze had overstated my hourly sleep. At 2pm I was totally inactive. But my blaze recorded in today functon on blaze screen. Itook 189 steps between 2pm and 3pm which is impossible as was watching t.v and dident move. I looked in settings and stride is set too auto and looks right think it's 313 inch. Can't remeber exacley. But I dident enter the 3 . Whatever it is. Assume my other info is going too inaccurate too idistannce and calories. Don' want info in today too be inaccurate as that defeats reason for buying and wearing blaze
06:17
07:03
04-10-2017
06:17
07:03
A warm welcome to the Forums @Jasonuk. Keep in mind that your Blaze might register some steps if you move your hands too much. To avoid this, you can restart your tracker and if the step count is really high, you can negate information by manually logging the activity "Driving" from your Fitbit app:
1. Tap the "+" icon
2. Tap Track Exercise
3. Enter your information
4. Tap Log it
5. Sync
I hope this helps, let me know how it goes. ![]()
Best Answer04-11-2017 21:23
04-11-2017 21:23
Hello thanks for reply. You mentioned if hands are moved a lot. That can affect step count. I'm mostly walking as moment. So should be able too keep my hands/arms under control. If this was not the case. You mentioned restarting my blaze. Would this be a one off thing. As in i would only need too restart bless once? Or would i need too restart it each time my arms. Or hands may of affected step count?.hear you sbout entering info in mannually. Would I
Just track my walking on my mobile phone. Like I do under exercise page on blaze screen?. If idident have my blaze with me. I get useing mobile then. But too use mobile when im wearing my blaze. Because it functions like a watch i would have blaze with me
So you track on mobile just because blaze is overestimating steps after i.ve eliminated arms waving and restart as possible causes of estimation of steps. Too track on mobile then just because blaze is overestimating stepcount. Don't sit right with me at all. I mean the blaze is not exacley cheap. As in it f
Cost a fair it. It's reasonable too expect it can count steps correctly. If h@
ad too use mobile because blaze not accurate. Would seriously re consider weither fitbit is right for me. As Manley bought it too count steps. And blaze should be capable of doing that propley. I will try and restriction movement and restarting blaze. When you advice id restarting is a one off or I a regular thing. But the phone tracking. Don't really solve the problem. It may make steps ' accurate. But it wont change fact blaze not working by counting step correctley. Like it said it would when I bought it..not a great start where I question ' info as in steps blaze is tracking. Maybe other fitness trackers are more accurate? . And I dr made a mistake buying blaze. Will soon know. Thanks for advice
04:08
07:03
04-16-2017
04:08
07:03
Thanks for getting back @Jasonuk. After doing the restart process, did you test the tracker? If you didn't, I recommend counting your steps. You can walk 100 steps and after that, let me know how many steps the tracker registered.
Hope to hear from you soon. ![]()
