08-17-2016 15:31
08-17-2016 15:31
Generally very pleased with my Blaze which I have had for about a month now. However, one thing that is frustrating has cropped up on my last two bike rides. The GPS tracking has randomly added some weird spikes (see below). Anyone know why this might be happening and if it can be avoided?
Best Answer08-21-2016 04:09
08-21-2016 04:09
It's great to see you around @timburdon. If your phone is not successfully tracking your GPS information, I recommend doing the following:
1. Make sure your device can track your activity when you're out of wi-fi range. To do so, tap Settings > Cellular and make sure Cellular Data is on.
2. Make sure the app can track GPS when your device is locked. To do so, tap Settings > General > Background App Refresh and make sure it's on for both the phone and Fitbit specifically.
3. Make sure your device is able to identify your location. To do so, tap Settings > Privacy > Location Services and make sure it's on for both the phone and Fitbit specifically.
For more information about GPS accuracy please see http://fitbit.link/1KMcmk0.
I hope this helps, let me know the outcome. ![]()
Best Answer08-21-2016 12:38
08-21-2016 12:38
Thanks for the reply, but I think you have misunderstood the problem. The gps tracking worked, but with the exception of a random spike (see pictures) - I'm confused as to why it would do this.
Best Answer08-21-2016 12:57
08-21-2016 12:57
Best Answer08-21-2016 13:06
08-21-2016 13:06
Thanks, that makes sense. I don't suppose there's any way to avoid it happening?
Best Answer08-21-2016 15:57
08-21-2016 15:57
