03-15-2016 14:02
03-15-2016 14:02
03-15-2016 16:57
03-15-2016 16:57
03-15-2016 22:07
03-15-2016 22:07
Best Answer03-16-2016 05:27
03-16-2016 05:27
Your not the only one. I have the issue also. They even sent me a new blaze, it didnt help.
Best Answer03-17-2016 09:52
03-17-2016 09:52
Best Answer05-24-2016 13:32
05-24-2016 13:32
Best Answer07-05-2016 19:34
07-05-2016 19:34
Did this issue ever get resolved? My run stride length is set accurately and I've verified it running known distances. However, the Blaze is underreporting by ~25%.
How is the Blaze calculating distance if the GPS is off and not utilizing the calculated stride length? Looks like an issue faced by quite a few. Customer service help will be really appreciated!
Best Answer07-05-2016 19:38
07-05-2016 19:38
Best Answer07-05-2016 21:28
07-05-2016 21:28
@qualitie i have moved your post out of the thread about steps, why hijack it, into the thread about stride and distance
Best Answer07-05-2016 22:07
07-05-2016 22:07
@qualitie without GPS the only option the Blaze has is to count the steps, then multiply it by the stride. If the distance is off then one of tge multipliers should also be off.
If your looking for an answer from cutomer service you might want to get intouch with customer service.
