02-07-2018
07:48
03:56
AlejandraFitbit
02-07-2018
07:48
03:56
AlejandraFitbit
My Blaze will not sync unless I go into my phone and force stop. The battery only last two days. This has been a ongoing problem. I shutdown the Blaze for a while then restart but still problem exists.
Best Answer02-08-2018 03:58
02-08-2018 03:58
It's great to see you around @9374146017.
Thanks for troubleshooting this by yourself. If you are having issues with your Blaze battery, I recommend taking a look at this post and follow the instructions provided there. Now about the syncing, follow the steps provided in the Having trouble syncing? post.
Let me know the outcome. ![]()
