12-12-2016 02:49
12-12-2016 02:49
The time went wrong on my blaze when charging last night. It is synced with my iPhone 6 and I use the Fitbit app. I have followed the advice from previous threads about unsetting and resetting the time zone and then resynching but this has not had any effect. I am not sure what force syncing means.
12-12-2016 04:26
12-12-2016 04:26
If you are syncing from the phone open the App. Tap on the Unit and sync now
Wendy | CA | Moto G6 Android
12-12-2016 08:17
12-12-2016 08:17
If what you have tried with the Timezones did not work, then check the time last synced, does it look good? If do I would add your tracker to your account as a replace my device.. This should cause the tracker to setup as if it was new to you.. You won't loose any data since it is already in the cloud.
