I discovered just now (May 18) that my fit bit blaze had not synced since May 4th. I tried to sync and it was saying "tracker not found." I unpaired my fit bit blaze with my phone's Bluetooth and tried to pair it again but my phone is not detecting my fit bit blaze. What do I do (I've only had it for almost a year)?
The best thing to try is to restart your phone and then restart your fitbit by:
Hopefully this will get it syncing again. Note though that the Blaze only has enough internal memory to store up to 7 days detailed data between syncs. After that it starts to hold data at a daily summary level. So, when you get it going again your data may look strange.
