11-18-2016
14:40
04:34
11-18-2016
14:40
04:34
Welcome to the Community @Lucyjane! Thanks for confirming that your tracker is in range to sync. I would like you to try this syncing procedure.
Also, you can try logging out of the app > force quit it finally, restart your phone.
Hope this helps. Let me know how it goes.
Best AnswerI'm having the same problem. It just started this morning.
13:45
04:34
11-19-2016
13:45
04:34
@Lucyjane Thanks for the troubleshooting that you've tried. If it's still not syncing then please contact Customer Support so they can further investigate it.
It's great to see you around @goodmorning! Have you tried the procedure posted above? Are you getting any error message?
Keep me posted.
