@Reevsie What happens if you launch some music on your phone? Mine states that until I start playing something on my phone - then from there I can control the music on the Blaze.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
@Reevsie I am using an iPhone as well, and don't have the BT classic setting showing anywhere either, but my controls work. What do you see if you swipe down from the top of the clock screen on the Blaze?
Kelly | Oklahoma
Kelly | Oklahoma
@Reevsie Glad you got it figured out. As for the GPS connection, you have to initiate it when you start an exercise. For example, on the BLaze I'll go to exercises, then click on "RUN". Then it will try to connect to the phone and the GPS. It will then say when connected. (There are certain settings that have to be enabled on the Phone to use this, but it will alert you if they are not turned on.)
Hope that helps!
Kelly | Oklahoma
Anytime! Glad you are up and running. Enjoy your Blaze! ![]()
Kelly | Oklahoma
