03-31-2016 15:08
03-31-2016 15:08
Best Answer03-31-2016 15:21
03-31-2016 15:21
Weights should be manually log as its not Step based
Wendy | CA | Moto G6 Android
Best Answer03-31-2016 15:23
03-31-2016 15:23
Best Answer03-31-2016 16:18 - edited 03-31-2016 16:24
If I understand your question correctly, there is a choice of Weights under the Exercise screen on the Blaze (assuming that you have selected it as one of the available options--there are many to choose from and you can select up to seven of them). You could select Treadmill first, finish that portion of the workout, then select Weights and complete that section.
Best Answer04-03-2016 19:33
04-03-2016 19:33
I use the "Weights Exercise" when pumping iron at the gym and it works for me.
