07-18-2016
07:42
10:39
FerdinandFitbit
07-18-2016
07:42
10:39
FerdinandFitbit
I have the Blaze paired to an iPod using Bluetooth Classic (do not get an option for the "ios" version of bluetooth). I can pause, skip a track, and go back a track but cannot adjust the volume. I have access to the volume screen but it does nothing. If I try the up or down button OR touch the plus or minus, it goes back to the previous screen. This totally defeats the purpose of hands free since all music is not recorded equally!!! Was unable to locate anything the boards about this particular issue.
07-08-2017 07:18 - edited 07-08-2017 07:28
For anyone still struggling with volume control not working but everything else works fine...I downloaded the Fitbit app to my device & synced it & now it finally works 😁 Before I synced with the app it would control play/pause & skip but not adjust volume! Of course this is the new Gen 6 iPod touch, not my older Gen 4 which is not on the compatible list. Hope this might help some people out. Cheers.
07-18-2016 08:48
07-18-2016 08:48
Hi there @dthom. Good to see you in the Community! 🙂
I would like to know which app you're using for your music. There was a similar situation with another user that was unable to control the volume of a track but it was with an specific app called Pandora (see the post here) which could be your situation.
Regardless of that, I would recommend in the meantime to restart your tracker by pressing and holding the left and lower right buttons for 10-15 seconds. Once you do this, the tracker will come back on by itself and you can try it out and see how it goes.
Let me know if you need more help!
07-18-2016 11:02
07-18-2016 11:02
Hi Ferdinand. I am using Apple's standard no-name music app that came with the ipod. Also, I read the other post that you mentioned and what I see on the volume screen is the plus sign, the volume speaker icon, and the minus sign. and when I press either button on the right side, it will either remain on the screen and the volume does not increase or decrease when pressing the buttons repeatedly or if you press and hold, it goes back to the clock screen. Do you know of an app for the iPod that actually utilizes the volume controls which is the only reason why the Blaze, and not another model, was purchased. Also, I've reset the Blaze several times to no avail. Also, after you mentioned the device's operating system, I checked to see if any of the settings were preventing the volume from being adjusted (like a listening default for children) and there isn't anything like that.
07-19-2016 05:29
07-19-2016 05:29
Thanks for getting back @dthom 🙂
I personally use Deezer for streaming music on my phone but I've also streamed videos from youtube or the native music app on my iPhone and I've had no problem at all so far.
I've not heard of users having issues with the native music app on their phones so I don't think this would be a common problem. If after restarting your tracker several times doesn't fix the issue, I'd recommend getting in touch with the Support Team and they will be happy to take a look into it and help you uout.
Hope this helps and let me know if you need more help!
10-08-2016 08:47
10-08-2016 08:47
I'm using my iphone and itunes downloads for my music. The issue is that I can't use the speaker on my phone to hear telephone calls, music or recordings. Can you help?
Lancelot
10-10-2016 06:38
10-10-2016 06:38
Hi there @Lancelot. Good to see you around! 🙂
I would just like to make sure. Just to see if I understan. You mean that when you're using your Blaze you can not use the speaker on your phone to listen to things on your phone or is it always that you can not use the speaker regardless of if you have the Blaze connected or not?
Please provide as much detail as possible.
01-06-2017 22:32
01-06-2017 22:32
I've just received my blaze as a gift and in setting up - I have the same problem using the standard apple music app ... I can >> (fast fwd) to the next song but the volume control isnt working... any update on what you did you fix your problem?
01-07-2017 14:39
01-07-2017 14:39
02-17-2017
07:51
08:29
FerdinandFitbit
02-17-2017
07:51
08:29
FerdinandFitbit
The problem is not the Blaze!!!
The problem is with the instructions in the guide. When you scroll down the clock to see the music playing, QUICKLY TAP and let go of the upper right button. The volume control with the "+ speaker -" will appear. If it goes back to the clock face then you have NOT quickly tapped the upper right button, instead you held it too long. Once you see the volume control, QUICKLY TAP, the upper or lower left button to control the volume. Once again if you hold it in too long, you will loose the volumn control.
I learned this by accident before getting into the car to return my 2 day old blaze to Verizon. It is 32degrees f. in NJ so I am glad I figured it out.
Someone needs to reprint the guide or manual for the Blaze.
Moderator edit: Format
03-07-2017 12:13
03-07-2017 12:13
Don't get the samsung watch! I bought it ONLY so I could control the volume of my spotify on my phone from my watch, and I swear that's the only thing it cannot do.
03-08-2017 09:28
03-08-2017 09:28
Hey @DcnJlm! Great to see you jumped in and thank you so much for sharing this with us!
@Rickylee68 @dthom, have you by any chanced tried out @DcnJlm's suggestions?
@tinychi, great to see you around as well!
Welcome you all to the Community and if you need more help, let us know!
04-04-2017 10:22
04-04-2017 10:22
That works great but your correct you really have to click the up down fast to get it to work
Thanks
04-04-2017 11:07
07-06-2017 08:01
07-06-2017 08:01
Think you had the same problem I have. Everything works except the volume control with the iPod! I checked that it's working on my android phone...the volume control works perfectly, just doesn't work with my iPod touch or my iPad Mini! I'm now looking at buying a different music player as Apple products never seem to like other devices/programs that aren't their own! Have you tried it with another device? It might be worth it before dismissing the Blaze. Whatever way you go, good luck.
07-06-2017 10:56
07-06-2017 10:56
@LouLouP are you able to pause your music on the ipod from your wrist?
Im wondering if the phone is to close and this bond is keeping the tracker from connecting to the ipod?
07-07-2017 07:22
07-07-2017 07:22
Thanks for replying. I use this for controlling my music when I teach fitness classes, so not close to my device. Yes it pauses/plays etc. It's just the volume, I think it's because my device is old (iPod touch 4th Gen). I've actually just ordered a new iPod Touch, fingers crossed 🤞
07-08-2017 07:25
07-08-2017 07:25
Which music app are you using, and how many have you tried?
Could this be a problem with the musi app?
07-08-2017 07:31
07-08-2017 07:31
Thanks,, hopefully you can see my edited post as I've solved the problem. Thanks again for getting back to me. Just for information...I use the default music player that's on the iPod touch 😊
07-08-2017 07:47
07-08-2017 07:47
