06-01-2018 02:12
06-01-2018 02:12
This morning my Blaze is displaying the temperature icon which I have never seen before. I've looked at other posts and tried the left/bottom button reset but that does nothing at all. It's locked on the temperature screen but does not feel either hot or cold to touch. Very frustrating!
Best Answer06-02-2018 06:20
06-02-2018 06:20
I know you said you restarted it. But doing that 3 times in a row can help.
If that doesn't help Contact Support.
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Wendy | CA | Moto G6 Android
06-04-2018 05:41
06-04-2018 05:41
It's great to welcome you @Ranga101 and @WendyB thanks for stopping by.
I appreciate the efforts in trying to fix this issue and would like to know if you followed our friend's recommendation and contacted our support team, have they offered a solution for this?
Hope to hear from you soon. ![]()
08-09-2018 01:10
08-09-2018 01:10
I'm also getting the temperature warning and the fitbit blaze stops working. It has just started and happens at odd times. Resetting even more than three times doesn't seem to help and the it sponaneously starts working again. Any suggestions as to what it means and why its happening?
