11-26-2016 18:32
11-26-2016 18:32
Hi,
Can i make suggestion to have option to turn off tap option on watch faces? I like the circuit watch face and i always want to set my little tracker on the watch to steps. But almost everytime i check, its always on other tracker such as steps, calories, etc.
I wish i can turn off tap feature only when viewing the watch.
11-28-2016 04:14
11-28-2016 04:14
It's great to see you around @Nixx. I think this is a great idea. Please check the Touch screen lock for Blaze request, vote for it and leave your comment. I hope this can be implemented.
Catch you later. ![]()
Best Answer11-28-2016 04:14
11-28-2016 04:14
Best Answer01-17-2017 14:01
01-17-2017 14:01
I agree with this request and think that it is somewhat different from turning off the touchscreen altogehter. I want to be able to use the touchscreen and have the watch function normally. But like @Nixx, I would like to be able to turn off the ability for the touch to change elements of the display on the clock face. I use the clock face Ace, and similarly like the display to show steps at the bottom. I would like to lock this so that it doesn't scroll through heart rate, calories, distance, floors, etc. I still want the watch to othewise function normally though. Same issue on Circuit and Moment clock faces as well.
