12-15-2017 09:08
12-15-2017 09:08
Hello everyone. I wonder how Fitbit Blaze detects the water we eat.
It is that I have already drank several glasses of water during the day and the dashboard continues the value of zero cups of water consumed.
Thank you for your help.
Best Answer12-15-2017 09:15
12-15-2017 09:15
Hello @nf76 Fitbit does not detect the water you drink. The user needs to manually add it.
The easiest way is to press the "plus sign" on the apps dashboard.
12-15-2017 09:15
12-15-2017 09:15
12-15-2017 13:28
12-15-2017 13:28
Thank you very much!
Best Answer01-11-2018 13:04
01-11-2018 13:04
Hi Rich,
Thanks for answering the water question. Do you know if there will be any updates allowing users to update water on their watch as opposed to the app?
Thanks,
Nathan
Best Answer01-11-2018 13:39
02-13-2018 05:52
02-13-2018 05:52
Hi Rich, yes. On this and a couple other water threads. Are you familiar with how the threads work? Do. They have to get a certain number of votes before they are flagged and is there a moderator that consolidates them?
Thanks,
Nathan
Best Answer02-14-2018 00:31
02-14-2018 00:31
Yes we try to consolidate. With sometimes 2, 3, I've seen as many as 6 identical suggestions in a 24 hour period, it isn't easy. When the do get merged the OP.'s vote doesn't get transferred.
Best Answer02-14-2018 05:28
02-14-2018 05:28
Thanks, Rich.!
