02-24-2017
11:53
12:30
SilviaFitbit
02-24-2017
11:53
12:30
SilviaFitbit
I have a HTC m8 running Windows 8.1 update 2. I am pondering about getting the blaze tracker put am worried that the GPS won't work with it.
Best Answer02-24-2017 12:34
02-24-2017 12:34
It's great to have you here @Masterchefkris! I was checking the list of supported devices and the HTC One M8 is a supported device. You can learn more about Connected GPS Information Post.
Additionally, you may want to check the Blaze Product Manual and get to know all the features you'll get with your tracker.
Hope you can enjoy your
Best Answer02-24-2017 12:40
02-24-2017 12:40
Thank you for the clarification on that for me I had seen mixed answers and just wanted to make sure before I bought.
02-24-2017 13:57
02-24-2017 13:57
I'm using an M7 and it's working fine.
Best Answer02-24-2017 19:22
02-24-2017 19:22
@Masterchefkris wrote:I have a HTC m8 running Windows 8.1 update 2. I am pondering about getting the blaze tracker put am worried that the GPS won't work with it.
There are two versions of this phone, android and a windows version.
Currently notifacations is not supported on windows phones, and the GPS uses the notifacations channel, therefore GPS is slso not supported.
