Hi, @DavidArline, if it has definitely had two or three hours charging (either on a computer that is awake and active) try giving it a restart. You may need to repeat this several times, but that can bring a Fitbit back to life.
It also can help to look at these battery charging troubleshooting tips in case the Blaze isn't getting adequate charge.
If none of that helps, you will need to get in touch with Fitbit Customer Support : contact.fitbit.com
