03-28-2017 19:11
03-28-2017 19:11
it has been six months since i bought my fitbit blaze. at that time i only used to charge onces in three to four days but recently my fitbits charge does not even last one day. i have not updated it, is that the reason?or is there any solution for this problem?
03-29-2017
05:07
08:47
03-29-2017
05:07
08:47
A warm welcome to the Forums @tiktatt and @Rich_Laue thanks for stopping by.
If you are having problems with your Blaze battery, I recommend taking a look at this post, where you will be able to find some instructions to follow regarding this inconvenience.
I hope this helps, let me know the outcome.
03-28-2017 21:34
03-28-2017 21:34
Have you done a restart yet? Hold in both the left and lower right buttons till the tracker kernel restarts.
I would also contact.fitbit.com and ask them to take a look at your tracker. They might even ask you to do a test then they can look at the results remotely.
03-29-2017
05:07
08:47
03-29-2017
05:07
08:47
03-29-2017 09:48
03-29-2017 09:48
thanks for your advice
03-11-2018 19:21
03-11-2018 19:21
I have a new Fitbit blaze and battery drains after a few hours.
12-15-2018 12:47
12-15-2018 12:47
My Blaze is draining in less than a day. Contacts are clean, I have tried the reset procedure. Unit is showing charge and full battery when charged. I have notifications turned off. There is some discoloration in the clear square below the contacts. Love my blaze but this is getting rediculous. Less than 9 months old.
01-23-2019 14:41
01-23-2019 14:41
I have had the same issues twice. The first occurred almost exactly 1 year to the day from date of purchase (actually 1 day after), but Fitbit was gracious enough to replace. The replacement unit lasted about 10 mo before the battery started draining in less than a day all of a sudden...AGAIN. When I called to see what Fitbit could do since it was still within a year from receipt of that unit, I was told this was common with the Blaze. They told me I was out of luck this time (past the 1 yr warranty...from the first unit), and offered me 25% off a new one. I don't want another Blaze so they offered 40% off an Ionic. So, I have to spend $160 after I was already sold crap product?? Lame attempt at customer satisfaction. I love what Fitbit products have to offer, but this is a bad look and makes me not want any of their products.
06-01-2019 00:11
06-01-2019 00:11
My battery has been draining in about 15 hours, and with everything that could be draining it turned off. I've turned it completely off thi try to reset it, turned off bluetooth, heart monitor, everything! I'm going on a European tour in 2 weeks and need a watch! This really stinks. My Blaze is only about 2 years old.
06-20-2019 12:22
06-20-2019 12:22
my fit bit blaze is just over a year old and this last week it has decided to die every single day. i have always been able to go 3 or 4 days between charging, no longer can i track my sleep, plus it is totally wrong on the tracking. we went fro a nearly 20 mile bike ride the other day and my fit bit only recorded 4, something is totally wrong with this and of course its out of warranty. I clean it regularly with rubbing alcohol and a super soft tooth brush it gets reset every time it dies which is daily now. any suggestions.
