hi actually I wanted to know that if I put my fit-bit device to charge and meanwhile I forgot to turn off the button of my charger will it harm my battery in other words if the battery is full but still the power was not turned off for several hours will it be a problem for my battery and the device help me know
thanks in advance
It's great to have you here @Chronos90! Your Fitbit tracker won't be damaged if you leave it charging for more time than when it's already charged.
Hope this helps!
Hope this helps!
