04-26-2016 19:01
04-26-2016 19:01
Best Answer04-26-2016 20:23 - edited 04-27-2016 21:33
My first thought would be to go to https://www.fitbit.com/compare where it is all spelled out.
So let's look at some highlights.
So what's the same?
Both count the same daily data.
Both have auto sleep.
Both can auto detect select events
Both have thee same notifications.
So what's different?
Blaze will use your phone's GPS
Alta can use the apps ability to record GPS
Blaze has the ability to directly track up to 7 types of events.
Three Alta is designed to do things automatically, while the Blaze can also do this, events can be started manually.for greater control.
04-28-2016 07:35
04-28-2016 07:35
Hello @soccerqueen1 and @Rich_Laue it's great to have you here! 🙂 I'm glad to know that @Rich_Laue helped you with the information you where looking for! Did you decide to get the Blaze for your sister?
Keep me posted! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer04-28-2016 08:09 - edited 04-28-2016 08:11
I addition to what Rich added, the Blaze has fantastic options for band changes to different leathers, steels, magnetic loops, and pretty much anything you want color wise to dress it up. Below is the Fitbit comparison:
So what's the same?
04-27-2016 19:23
04-27-2016 19:23
Best Answer04-28-2016 07:35
04-28-2016 07:35
Keep me posted! 🙂
05-01-2016 20:45
05-01-2016 20:45
Best Answer05-02-2016 03:05
05-02-2016 03:05
Hi,
I have just bought Blaze yesterday. I like it now but before buying I liked Alta more. For me, the problem is that Alta does not have heart rate meter so that was the reason why I choose Blaze.
Best Answer05-13-2016 06:38
05-13-2016 06:38
Hello @soccerqueen1, @racertempo and @Darklydexter thanks for taking the time to visit this thread. @soccerqueen1 you still have some time to decide the perfect gift for your sister.
Keep me posted! 🙂
Best Answer05-16-2016 09:45
