I have had a blaze for a few months now and have really liked it. With this last upgrade however I noticed that it does not always track sleeping correctly. It has been off by between 1 and 3 hours ever since. It knows when I wake up but has a hard time telling when i fall asleep. I have a few other unrelated problems that have just started occurring since that update as well so they must have messed something up. I'm sure it will be fixed soon.
Best AnswerI think the suggestion was to adjust the sensitivity of your fitbit or to reset the watch
Hello @mmtj welcome to the Fitbit Community. It's great to have you here 🙂 Your Blaze uses Autodetection to track your sleep. Autodetection is based on your movement. When you haven’t moved in over an hour, algorithms assume that sleep has begun, which is confirmed by the length of time your movements are indicative of sleep behavior only (rolling over, etc). Morning movement tells your tracker that you’re awake. If you’re not moving but not asleep for long periods of time it’s possible for your tracker to falsely record sleep, in which case you can delete the sleep record from your dashboard. Because our auto-detection algorithms require time to confirm that you’re awake for the day, it takes about an hour for your sleep log to appear once you’ve synced in the morning.
If your sleep is not being recorded, restart your Blaze and review your sleep tracking sensitivity to movement as advised by @Rich_Laue. @fudge22 thanks for your cooperation.
I'll be around if you have any questions. 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
