problems with hour on my watch
I am trying to change my blaze from 24 hr to 12 hr and I have attempted several times with no prevail.
Anyone else with this problem?
4 REPLIES 4
@melissaarmijo10, are you changing the setting on this page, and then doing a sync, or is it tyat you cant find tye page to set it.
It's great to see new faces @melissaarmijo10, welcome! And @Rich_Laue thanks for stopping by.
As mentioned, you need to do this from a computer since there isn't an option to change the timezone from 24 hr to 12 hr from the Fitbit app. From a computer do the following:
  1. Click the gear icon
  2. Go to Personal Information
  3. Scroll down and click on Clock display time.
  4. Select 12 hr
  5. Sync
I hope this helps, let me know the outcome. Woman Happy
I am doing it on the settings where it gives you the option to set it and it refuses to stay on the 12 hour icon.
I have been doing just that but to no prevail.  I do not know what I am doing wrong.
