04-19-2016 16:57
04-19-2016 16:57
Best Answer04-20-2016 06:01
04-20-2016 06:01
Welcome to the Community @musicalseph. First, I recommend checking if your girlfriend's phone is a Compatible Mobile Device. In the meantime, please try the Setup Process from a computer.
I hope this helps, let me know the outcome. ![]()
Best Answer04-20-2016 06:02
04-20-2016 06:02
Hi there @musicalseph. Good to see you in the Communtiy1 🙂
First, please be sure that her phone is compatible by checking in the compatibility list (click here for that). Then make sure that you're setting up the tracker from the Fitbit app and not from the bluetooth settings on her phone.
If nothing helps, try to restart the tracker by pressing the left and lower right buttons for 10-15 seconds until it restarts and try one more time. Also restarting her phone and turning off and back on the bluetooth could help.
Hope this helps and let me know if you need anything else!
