03-26-2019
12:23
06:16
AlejandraFitbit
03-26-2019
12:23
06:16
AlejandraFitbit
My Charge 3 screen is excessively dim, even with a full charge. I've tried restarting it with no result. It will occasionally come on bright but after a few seconds it's dim again and I can't get it back. This is indoors and is still difficult to read. Outside with any amount of sunlight, it's impossible to read.
Hi everyone. Thanks for trying to troubleshoot the issue with your Charge 3 as suggested here.
At this moment, the limits of what we can do for you here on the public community forums have been reached. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
This thread is now closed. If you have a different problem, find a similar thread or post it in a new thread.
03-27-2019
06:18
09:31
03-27-2019
06:18
09:31
A warm welcome to the Community @747pilot.
Thanks for troubleshooting this display issue by yourself. Have you checked if your tracker's brightness is the one you selected? If you haven't, I recommend trying the following from your Charge 3:
Let me know the outcome. ![]()
I have the same problem. Nothing helps. I love my Fitbit Charge 3, but it is difficult to read indoors and impossible to read outside! The brightest setting in the device is woefully dim. Can we get a software or firmware update to fix this please??
04-04-2019
05:53
04:20
AlejandraFitbit
04-04-2019
05:53
04:20
AlejandraFitbit
In both the auto setting and normal for brightness, I can just barely make out the time only because it is in a large font. Anything in a small font is impossible to read. This is indoors with using my reading glasses! Getting ready to toss it.
No. In either setting, normal or auto, the display is the same. Too dim to read even inside. I can make out the time only because it is in a large font. Anything in smaller font is very difficult to read even with reading glasses on. Getting ready to toss this thing.
Moderator edit: content
04-07-2019
04:25
09:31
04-07-2019
04:25
09:31
It's great to see you here @747pilot, @phatlad and to welcome you @DibAgain.
I know that it would be great to have an option to increase the brightness on the Charge 3. Please take a look at the Charge 3 - options to increase brightness please request, vote for it and leave your comment.
I will see you around. 🙂
04-12-2019
06:23
09:31
04-12-2019
06:23
09:31
It's great to see you here @Megib.
If your tracker's display is too dim, I recommend verifying your brightness preferences by swiping to setting and tap the brightness option. If this doesn't work, try to restart your Charge 3 by following the instructions provided in the help article How do I restart my Fitbit device?.
My screen has completely ceased to function.
However, I want to confirm here that Fitbit, after contacting them and going through some tests with the device, is replacing my tracker for free. I'm hoping that the new tracker doesn't suffer from the same issue. At any rate, thanks to Fitbit for taking care of a community member.
My display is literally too dim to do this. I cannot see anything on the screen well enough to know where I am or whether I am in settings. This combined with the constant losing connectivity is driving me to another watch.
I had the same issue. FitBit, after contacting them and establishing through some different steps that the device was defective, replaced my Charge 3 for free, and the replacement has functioned flawlessly to date.
My choices on settings are auto or normal and normal isn’t bright enough, but before the last update it was plenty bright
This has been my problem too! Somehow my screen was set to dim after I tried to brighten it. Probably because I couldn't see what I was doing!! I have really really struggled to put it right. Ridiculous Fitbit! Please sort it out!
Naw, this product is a P-O-S and company doesn't give a rats butt about what USERS want!! I'm trashing mine to find one which is visible Inside AND OUTSIDE! What good is a device which you can not read Outside?
Never have seen such a company so apathetic to it's customers and refusing to listen to their wants and needs!!
I would like to point out again that FitBit replaced mine free of charge when mine turned out to be a lemon. They were courteous and timely, and I can't be happier with my new one. If you haven't contacted the company directly yet, please consider doing so before making another purchase when you may be able to get a replacement for free that works the way you'd want it to.
