08-13-2022 18:27
08-13-2022 18:27
If you search the manual for "AZM notifications", you get no results. This is interesting because there is an option to turn on our off the aforementioned setting. I did manage to figure out the acronym but it seems odd that a configuration option does not rate a mention.
Best Answer08-14-2022 05:15
08-14-2022 05:15
Hello @Boggledorf and welcome to the Community. Like @Edmond wrote, AZM stands for active zone minutes. The Charge 5 will give you these notifications under two scenarios: for everyday activity and when using the Exercise app. You need to turn them off everywhere to make sure they are off. Here's the Charge 5 section from Fitbit's Help article.
I think there is a typo. Fitbit wrote Weekly notifications, but I'm sure they mean the everyday activity notifications. I wear a Luxe and it's navigation is the same as the Charge 5. You must turn them off in every exercise shortcut that you use.
@billion_steps These notifications are triggered by your heart rate, not your calorie burn. Please review your settings.
Laurie | Maryland
08-13-2022 18:34
08-13-2022 18:34
Disabling AZM notifications in the settings menu of the watch wasn't enough, to eventually get rid of all AZM notifications I've had to set main goal = calories and calorie goal = 10.000 (intentional, it's never reached) in the Android app
settings for this are scattered across different menus, quite confusing if you just want the watch to shut the fu#% up
08-13-2022 22:10
08-13-2022 22:10
I saw "AZM" and thought "what is that?" But, I figured it must be in the manual, so I put it off till later.
You got me. What does the acronym "AZM" stand for?
Best Answer08-14-2022 00:09
08-14-2022 00:09
Active zone minutes notification
08-14-2022 05:15
08-14-2022 05:15
Laurie | Maryland
08-14-2022 07:32
08-14-2022 07:32
I'm aware of that, you misunderstood me.
From my experience, the only way to get rid of all AZM notifications during the day (not only during exercise) you have to change "main goal" from AZM to calories and then set a daily calorie number target so high that it's never reached (or else you'll be bugged with calorie notifications)
Unfortunately there's no other way than this to make the watch shut up
Best Answer08-14-2022 08:50
08-14-2022 08:50
@billion_steps I read and re-read your post. Fitbit makes you set a main goal and comes with 10,000 steps as a default main goal. You can set other parameters as your main goal. When you changed that setting to calories, with that high number, you were setting you main goal celebration. Again, AZMs come from heart rate and nothing else. Trust me on this.
Laurie | Maryland
Best Answer08-14-2022 10:20
08-14-2022 10:20
I feel your pain😠😠😠😠.
I find that it sends a notification just as I am finishing a long timed bike ride.
Therefore prevents pressing the stop / finish icon of the workout until the notification has completed its "RaRa" that a go😆 boy dance".
Not something anyone needs at a time when one is struggling for a breath at the same time trying achieve a new timed PB only to come up short because of this nussaance delay to press finished. So this discussion is quite timely helping me resolve my 😠😠😠😠 untimely frustration.
08-14-2022 14:43
08-14-2022 14:43
Best Answer08-14-2022 14:47
08-14-2022 14:47
08-15-2022 02:07
08-15-2022 02:07
It does with lap notifications as well!!!! A few times I finished my 10 mile run bang on the time it lets me know I've done another mile....it then sticks on the screen for what seems like for ever before I can then finish my run.
Best Answer08-27-2022 05:25
08-27-2022 05:25
I think you missed the point. I said that I had figured out what AZM notifications were. My issue is that searching for "AZM Notifications" in the manual returns no results.
