Feel bad posting this will all the craziness going on with the latest update. I'm just coming back to Fitbit after trying some others in the marketplace. Much has changed, good and bad, but my question is around the Alarm Settings and Vibration.
In the past I recall "Smart Wake" behavior was different. The tracker would start a very gentle vibration and build up to full strength at your designated alarm. Now it just goes off 30min prior to the set alarm at whatever strength you've set. Am I missing something? Is my device not working properly? Was this setting changed from the past? I guess I don't see the point in the feature as it stands now. If I want to get up 30min sooner I'll just set the alarm at that time.
Thanks for any insights you might have.
Best AnswerHi @kjasonadams there are two different alarms - one for the usual alarm and one for the smart wake - each having their own symbol.
Best AnswerThanks for the link, I know how to set them. Maybe read the question first.n
