07-25-2022 08:42
07-25-2022 08:42
I bought a Charge 5 after doing FitBit updates. My charge 2-3 didn’t work afterwards.
After talking to support I am disappointed that my Charge 2-3 won’t work with Charge 5. I would like to use my older models for yard work, and as backups.
Best Answer07-25-2022 09:03
07-25-2022 09:03
@Gsfit4 You can keep your Charge 2 on your account for the dirty jobs along with your Charge 5. Fitbit created a device limitation when it created the Gallery. You can only have one Gallery enabled device on your account at a time. Unfortunately you can’t have your 3 and 5 on at the same time. You can save the 3 as a backup. But you will need to replace the 5 with the 3 to use it.
Laurie | Maryland
07-25-2022 09:03
Laurie | Maryland
