Hi, anyone else being right on the numbers when it comes to wrist circumference? I'm 165mm, 160 mm if I wear it tight but would never of course tighten it that much in real life.
Size small is 132-165mm
Large 165-230mm
Which one did you go for?
Anyone else with similar experience?
Best AnswerI think all new watches come with both sizes; one end is the same but the other end has small and large size that you can use either one.
Best AnswerI see. So better to order the main unit itself before ordering more straps and try out which one is best.
Best AnswerI see now, for accessories the extra bands come by sizes. I was just thinking of the original watch purchase.
I guess I'm no help in that case.
